Bavaria Sail Boat - Propeller Recommendation
Author Topic: Bavaria Sail Boat - Propeller Recommendation  (Read 2508 times)
dmfranch
« on: February 02 2022, 16:56 »
Which is the right 3 blades prop for my
Bav 40 2001 with engine MD22L BT  and drive Unit  120S-E 2.20
Re: Bavaria Sail Boat - Propeller Recommendation
« Reply #1 on: February 02 2022, 20:32 »
17 x 15 left Geoff on 40cc 2001
dmfranch
« Reply #2 on: February 02 2022, 22:34 »
Is not 40 cc
Is 40 3 cabins
Does it make any difference?
« Reply #3 on: February 02 2022, 22:46 »
No. 17*15 was fitted to many boats of around 40' and the 50hp engine. First check the prop you have - the size will be stamped on the boss but often difficult to find under years of crud. second a way to check that the size is correct is to do a run at maximum with a clean bottom and flat water. You should be able to get within 200rpm of the quoted maximum rpm for the engine.
Note that the size is only for the fixed 3 blade. Folding and feathering props are often a different size and best to check with the maker of the prop for the recommended size.
« Reply #4 on: February 03 2022, 06:45 »
If you have the old prop available and it was correct dimension, here are instructions, template and app on how to determine size (incl. pitch) https://sites.google.com/site/thepropellerhub/simple-pitch-measuring
Our three-blade folding (Volvo) prop is 18x15 on 2001 3-cabin Bavaria 40 with MD22 engine
An older thread on same topic http://bavariayacht.org/forum/index.php/topic,2289.0.html
BR,
Tommi
s/y Anniina
dmfranch
« Reply #5 on: February 03 2022, 12:02 »
Thanks to everyone for your help, always valuable
