Traveller End Caps
Author Topic: Traveller End Caps  (Read 2130 times)
HappyAfloat
    • www.happyafloat.com
Traveller End Caps
« on: January 30 2022, 14:26 »
My traveller end caps are looking worn so I would like to replace them.  Also, I am not happy with the current design as the main sheet occasionally gets caught.  So I am planning to make my own replacements.  However, I am not sure which material I should use, something UV stable, any suggestions?
Re: Traveller End Caps
« Reply #1 on: January 30 2022, 15:37 »
Original is almost certainly ABS, which is the right choice of plastic for the job. PP or PE won't last well in the sun. Black PA (Nylon) with UV stabilizer should work too, but can be difficult to source.
« Reply #2 on: January 31 2022, 06:58 »
As they seem pretty flat, cut them out out a sheet of aluminium..?
HappyAfloat
« Reply #3 on: January 31 2022, 18:54 »
Thanks for the suggestions.
I'm not much of a metal worker so I will try the ABS first.
I have mocked up an MDF version while waiting for the ABS sheet to arrive.
Anything obvious I am missing?
HappyAfloat
« Reply #4 on: February 26 2022, 12:05 »
The finished product.
« Reply #5 on: February 26 2022, 13:15 »
Well done  :)
