Battery separator
Author Topic: Battery separator  (Read 2988 times)
kavok
  • Boat Model: 40 Cruiser
Battery separator
« on: January 18 2022, 19:01 »
I broke the original battery separator, Blu color, USA production. I tried to mount a Victron Mosfet separator, but, closing engine master switch, remain 1,2.amp on
 engine battery on panel 301 and red led flash. This without start the engine. Any suggests?
Re: Battery separator
« Reply #1 on: January 19 2022, 12:58 »
Which kind of mosfet separator? Does this separator have a trigger input? Any schematics available?
kavok
« Reply #2 on: January 19 2022, 15:27 »
Victron Argofet 200-2. There is  trigger but
is not necessary with Volvo Penta generator. There is also a ground connection that I activated.
Probably Bavaria 2008 electric system is good only with diode separator.
I am buying a Quick ECS 162 that has built in mosfets+ diodes and run good in a boat like mine (40 Cruiser m.y.2008)
« Reply #3 on: January 19 2022, 15:55 »
Can't see why an ArgoFET wouldn't work.
If you're buying an ECS162, you might as well get the ECS163 - it's only around €20 more and the third output might be useful in the future (eg for a bowthruster battery).
« Reply #4 on: January 19 2022, 20:32 »
Maybe your VP MDI/ EVC is on and drains the starter batt?
kavok
« Reply #5 on: January 19 2022, 21:16 »
Surely no.
kavok
« Reply #6 on: January 19 2022, 21:19 »
kavok
« Reply #7 on: January 19 2022, 21:28 »
I can not tell why it does not work.
Surely it happened in other 40 Cruiser my2008.
Quick seller know the  Victron issue and he told me if the reason that Quick work good on Bavaria is that Quick separator has mosfet+ diodes.
kavok
« Reply #8 on: January 26 2022, 13:22 »
Quick ECS 162 work fine.
