Autopilot replacement for Bavaria 44, EV-200 or EV-400
Author Topic: Autopilot replacement for Bavaria 44, EV-200 or EV-400  (Read 4741 times)
Bjorn_J
Hi!
I have an old Bavaria 44, 2004 with a Raymarine course computer 150.
I would like to replace it with a new Raymarine EV-200 or EV-400 autopilot.
The ACU-200 drive unit is rated 15A and ACU-400 is rated 30A, both at continous load.
The drive/gear is Lewmar Mamba standard for Bavaria 44 (89200092) and the electrical motor is rated 1/4 hp (appr 186W) at 12V, average cosumtion 4A.
The recommendation for the Lewmar Mamba motor is a 16A circuit breaker.
The question is if the ACU-200 is large enough (it is on the edge at max load)? The ACU-400 is much more expensive.
Have you tried one or the other?
Kind regards
Björn Johansson
Re: Autopilot replacement for Bavaria 44, EV-200 or EV-400
« Reply #1 on: January 07 2022, 08:46 »
No first hand experience on said combination, but my engineering-thought:
1/4 HP max rated power is almost exactly 12V x 15A, so if it was my boat, I would not hesitate to use EV-200.
BR,
Tommi
s/y Anniina
Bjorn_J
« Reply #2 on: January 10 2022, 18:09 »
Hi Tommi,
I have the same engineering thoughts.
Kind regards
Björn
kavok
  • Boat Model: 40 Cruiser
« Reply #3 on: January 10 2022, 21:05 »
A good ratio between computer power and motor average consumption is 5
For our motor that use average 4 amp, we need 20 amp computer.
Ev 200 is too small , 15 amp, in rough conditions when the autopilot must be affordable
EV 400  is rated 30 amp, in this case we have more reserve power.
I put Ev 400 on 40 CRUISER my 2008 and I am very satisfied in wind mode navigazione.
Baltic
  • Boat Model: B39
« Reply #4 on: January 14 2022, 20:47 »
Hi.
" Mamba standard for Bavaria 44 (89200092)"
Lewmar SKU might be  89300053  (Mamba 1/4hp 12v Std)
I am not  an engineer.
But. I think in this case 1/4hk does not mean 1:1 electric motor power 186w  and P=U*I...  15A.
We have Lewmar autopilot Integra drive 89300111.  1/8hp
Specification:    AVERAGE CURRENT  CONSUMPTION 4A, MOTOR 16A CIRCUIT  BREAKER,  CLUTCH 2A
Electric motor is Kenlowe KLM2189 ,  Output power 64w,  Rated Current 8.3A    (~ 1/8hp)
We have used it 15 years with Raymarine S1 smart pilot.
Specification:   Drive motor output:   continuous 5 A at 12 V,  Drive clutch output:   1.5A at 12 V  (FUSE 10A)
With 12V and without extra load drive motor will draw less than 2A.   And 10A fuse is working fine without any problems.
I just want to say..
It is possible to use 1/8Hp and 8.3A  (Rated Current)  motor with the S1 course computer with 5A drive output without any problems.
 (Rated Current) = Internet says... "The current drawn by a motor at its full load"
My opinion...  Mamba 1/4hp 12v Std  Rated current could be that  186w ~ 15A.
ACU-200 15 A (maximum continuous output)   And Fuse is 20A
As Tommi and Björn told
If it my boat..   Hard to see any reason to pay extra and buy ACU-400.
The clutch might be a more interesting question...
« Reply #5 on: January 17 2022, 07:29 »
Why change the AP, if it is functioning? A new one does nothing else than the old one (exept draining you some 1000€ from your wallet). Yes, the new pretty shining displays.... but worth a fortune?
kavok
« Reply #6 on: January 17 2022, 11:49 »
New generation autopilots are a big improvement in spite old, specially in sailing mode and strong conditions.
Bjorn_J
« Reply #7 on: January 20 2022, 16:43 »
thank you all for all the thoughts and recommendations. I have decided to go for the EV-400 to have soem extra margins.
Kind regards
Björn
kavok
« Reply #8 on: January 20 2022, 22:35 »
Righ choice.
