Raytheon chart plotter shows no fix
Author Topic: Raytheon chart plotter shows no fix  (Read 4197 times)
Scallywag too
« on: July 18 2013, 16:14 »
My chart plotter is showing no fix is there a way of testing the areal or should I just buy a new areal does it have to be a raymarine part
Re: Raytheon chart plotter shows no fix
« Reply #1 on: July 18 2013, 16:48 »
Some of these aerials have a battery that has a life span of about 10 years, ask your agent or look on support for the product
njsail
« Reply #2 on: July 19 2013, 03:11 »
We are having the same problem with our Raymarine c80 chartplotter. I already tried replacing the small battery in the antenna in it. I'm still having intermittent issues. for my next trick I'm going to try replacing the small antenna which I believe is a few hundred dollars. many of the newer chartplotters have a GPS built in but I really don't feel like spending thousands of dollars chartplotter that should be able to keep a fix. since I spend a lot of time in shallow water I keep a spare handheld GPS / chartplotter on just in case I need to fix which is often. please let us know how you make out solving your issue.
