Bavaria 40: Where is the exhaust water lock?
Author Topic: Bavaria 40: Where is the exhaust water lock?  (Read 1869 times)
Krumelur
« on: November 01 2021, 10:01 »
I’m reading through my boat’s manual and am looking at something called “exhaust water lock” (number 3 in attached schematic).
This thing sounds to me as if it could be prone to rust and I would like to check it.
But I don’t know how - it seems to be located under the fuel tank.
Any ideas?
Re: Bavaria 40: Where is the exhaust water lock?
« Reply #1 on: November 01 2021, 10:14 »
Most likely next to fuel tank close to boat centerline. This is the location at least on my 2001 model.
Follow the exhaust tube from engine -> you'll find it easily.
BR
Tommi
s/y Anniina
« Reply #2 on: November 01 2021, 10:55 »
On the drawing it's in the gap between water and fuel tank, so should be accessible there. I wouldn't much trust the drawing though and do as Tommi says - follow the exhaust hose from the engine :)
« Reply #3 on: November 11 2021, 10:43 »
it is under the Port berth close to the centerline of the boat about half way along the berth. The water separator started leaking about two years ago and I replaced it with a plastic one. Just need to fit an exhaust temperature alarm and then I will be a lot happier.
