Where to connect inverter
Author Topic: Where to connect inverter  (Read 3904 times)
marioxp
« on: October 12 2021, 12:39 »
Previous owner connect inverter (600W) direct on batteries, it seems to me that is not good solution, because inverter bypasses fuse and main switch.
What is your recommendation?
My idea is connect inverter after main switch, I hope to find a main positive busbar where I can connect.
Re: Where to connect inverter
« Reply #1 on: October 12 2021, 13:30 »
You want the shortest possible cable lengths.
« Reply #2 on: October 12 2021, 13:59 »
Indeed, ours are about 300mm max. We also fitted a high load isolator on the +ve lead..
marioxp
« Reply #3 on: October 12 2021, 20:37 »
I understand that with length resistance rise, but with appropriate diameter of wire resistance and consequently voltage drop is negligible. BTW my inverter is medium requirements.
My question is where is point to connect inverter.
« Reply #4 on: October 12 2021, 21:48 »
As close to the batteries as possible.
Jake
  • Boat Model: 44
« Reply #5 on: October 13 2021, 02:10 »
Wherever you install it, include an appropriately sized fuse as close to the battery as possible.
Jake
Jake Brodersen
Winedown
Bavaria 44
« Reply #6 on: October 13 2021, 08:06 »
Mine (350w) is wired to one of the auxiliary switches on the DC distribution panel.
« Reply #7 on: October 13 2021, 16:02 »
I make that about 28/29Amps (max). I think all ours are rated at 10 & 15Amps each but I may be wrong...Bill
Zolden
  • Boat Model: Bavaria 38.2
« Reply #8 on: October 14 2021, 08:03 »
I have a 1600w inverter conneted to 12dc just after the main fuse. The inverter have Owen fuse and breaker. Works perfect
marioxp
« Reply #9 on: October 14 2021, 15:17 »
Yes it is one option, i definitely don't want to connect before the main fuse.
Does anyone know if Bavaria 2003y has any main positive busbar, and how to reach it.
diverphil
  • Boat Model: 33 cruiser
« Reply #10 on: October 14 2021, 19:33 »
would it be possible to wire it across 24v of house battery's with its own fuse and switch, would draw less amps through the wiring (assuming you are fitting a larger wattage inverter) ?
« Reply #11 on: October 15 2021, 08:53 »
Usually Bavarias only have a negative busbar. If you attach a cable lug to the +-connection of your inverter, you should be able to attach it to the switched side of your main switch.
I connected my inverter(1500W/ 150A) with a separate circuit breaker to avoid longer cabling, see picture
artemis
« Reply #12 on: October 21 2021, 16:25 »
Have a look on youtube martins videos
 https://www.youtube.com/watch?v=gfAfDX9P4HE
Mike
Artemis
