Bav 36 anchor fuse
Author Topic: Bav 36 anchor fuse  (Read 1891 times)
Goboatingnow
Bav 36 anchor fuse
« on: October 03 2021, 10:06 »
Bavaria 36 2003
I was wondering if the anchor windlass has a fuse or breaker. I can identify the relay , but not a high current fuse or breaker
Goboatingnow
Re: Bav 36 anchor fuse
« Reply #1 on: October 03 2021, 10:47 »
I discovered a 100A fuse behind the dc panel. That’s scheduled to be upgraded now To  a breaker
« Reply #2 on: October 03 2021, 16:51 »
Ours is also behind the control panel, just to the right of the two large windlass relays. (Relays and fuse are mounted on the inner face of the hull)....Bill.
diverphil
  • Boat Model: 33 cruiser
« Reply #3 on: October 14 2021, 19:52 »
our 33c has 2 breakers/fuses under the bench seat in front of the chart table, one for anchor the other for house, I think they are rated at 100amp and 125amp but never had to change them(so far ;) ),. maybe I should get a spare set in case ::)
Trundletruc
« Reply #4 on: October 22 2021, 19:32 »
Bavaria 36 2002. The fuse is a big ceramic one (100amp} on the left when you swing the switch panel out of the way. Follow the thick red wire from the control box to it.
