Which Perkins engine is the D1-30 circa 2015?
Author Topic: Which Perkins engine is the D1-30 circa 2015?  (Read 2520 times)
GeoffV
  • Boat Model: Bav 37 Cruiser
  • Boat Year: 2016
« on: September 12 2021, 13:26 »
I am doing away with the MDI unit, button panel to make the system simple and reliable with standard instruments.
What I need to do first is the temperature and oil pressure gauges for which I need unit size holes and thread type. Hence request for original engine block.
Ta in advance for all help.
Re: Which Perkins engine is the D1-30 circa 2015?
« Reply #1 on: September 12 2021, 16:34 »
It is a Japanese Perkins Shibaura engine. Your best bet is https://www.parts4engines.com
GeoffV
  • Boat Year: 2016
« Reply #2 on: September 14 2021, 13:24 »
You don’t happen to know the thread sizes for temp and oil senders do you?
« Reply #3 on: September 15 2021, 10:39 »
Sorry, never needed to look!
beeblebrox
« Reply #4 on: September 16 2021, 11:57 »
I changed the water temp sender several years ago from switch/alarm-only to an analogous temp sender with an additional switch from VDO. Same Engine, D1-30. Thread is M18/1,5. I needed an adapter M14->M18 as the sender from VDO was M14.
GeoffV
  • Boat Year: 2016
« Reply #5 on: September 16 2021, 12:16 »
Thank you so much for the information Beeblebox. I can move ahead and order that.
Just the oil sensor thread size to go.
beeblebrox
« Reply #6 on: September 16 2021, 13:43 »
Hi Geoff,
you're welcome. The replacement of the original oil pressure switch (alarm only) with a sender unit is also on one of my todo-lists - but with a lower priority :-) But if i remember it correctly (found somewhere in the net) that is NPT 1/8. SVB sells KUS senders : https://www.svb24.com/en/kus-oil-pressure-sensor-0-5-bar-10-184-ohm-with-alarm.html. And it might be that you will need an 90 degree adapter, because of little space (bigger diameter of the sender compared to the switch).
But - i am not 100% sure that this is the fact, because I haven't checked that. If you find out, it would be great to share it here :-)
Lutz
« Reply #7 on: October 01 2021, 08:58 »
I can confirm the 1/8NPT for the oil pressure sender on a D2-75F, which is of the same shibaura engine type family.
Fitted such a combined sensor(switch and analog sensor), connected the switch to the original input on the MDI and the analog sensor to the new instrument (0-5bar). According to VP spare part list the sensor on D1-30 and D2-75F should be the same, but worth further investigation
GeoffV
  • Boat Year: 2016
« Reply #8 on: October 01 2021, 09:08 »
Did you fit the new oil sensor low down on the left hand side of the engine as you look at it in the normal place?
I recently found some info in a forum where people were fitting them to an area at the front of the engine where there is an allen bolt screwed in. I am going to look at that when I go to the boat this saturday.
