Saloon table modification
Author Topic: Saloon table modification  (Read 3248 times)
« on: August 25 2021, 14:36 »
This is for all of the sailors who like me have difficulty accessing the lockers around the dinning area,  just getting into some is a Houdini trick,  so I have altered Odysseus.
I wanted something easy to do, low cost, and would fulfil the requirment completely.
1  separate the table top from the base, its screwed in 4 places, and the glue it tuff stuff to cut through with a flat plate vibrator tool. After the completion of one side you can rock the other side to part cleanly.
2  clean up all glue and sand off the damaged areas of glued locations.
3  with the new wood or other material, ( mine is a piece of shower walling because its smooth) screw and fix to top of table base.
4  the slide retaining fittings are then placed on upside down table centrally, tight but still allowing easy movement. Screw into place. I spayed furniture polish on my table and new material stand.
5  screw in position  a small stainless bolt to retain table when at sea or not in use.
Re: Saloon table modification
« Reply #1 on: August 27 2021, 14:43 »
Nice modification :)
Krumelur
« Reply #2 on: November 05 2021, 10:20 »
Love it!
