rudder bearing maintenence
Author Topic: rudder bearing maintenence  (Read 6871 times)
« on: July 06 2013, 18:06 »
Just for information, bearing maintenance when lifting out.
Put half a cup of oil in the rudder housing before you lift out by unscrewing the top jubilee clip around the housing and jamming a small funnel down in between housing and stock.
When you lift out the water leaks out of bearing housing then the oil, so, move the rudder back and forward continually when the oil flows.
Hope this helps, or you can put new bearings in !!
Stuart
Re: rudder bearing maintenence
« Reply #1 on: July 07 2013, 13:16 »
Hi Thanks for posting this, what kind of oil is it ?
Stuart
Stuart
« Reply #2 on: July 07 2013, 16:02 »
I use standard engine oil, but most oils would be suitable. The oil only runs out when the boat is lifted out of the water. Makes a bit of a mess if you don't put a bucket under it.
Stuart
« Reply #3 on: July 07 2013, 16:47 »
Hi Odysseus
Thanks for the reply will try it before we launch this winter.
Stuart
Stuart
nornie lees
  • Boat Model: 30 cruiser
« Reply #4 on: July 14 2013, 12:07 »
thanks for the info , got to be better than wd40, which i used last week!!!
