2000 Bavaria 34 - Navigation Lights
Author Topic: 2000 Bavaria 34 - Navigation Lights  (Read 2172 times)
LinTeal
« on: August 04 2021, 22:24 »
It is not immediately obvious to me as to how you remove the covers on the deck navigation lights..Advice would be appreciated .
Re: 2000 Bavaria 34 - Navigation Lights
« Reply #1 on: August 05 2021, 06:51 »
Can you show us which lights those are with a photo or specify the make and model?
« Reply #2 on: August 05 2021, 08:06 »
On some models there is a button on the base which enables the cover to slide off.
artemis
« Reply #3 on: August 05 2021, 08:58 »
If its the nav light port/Stbd on the pulpit if I mind right there is a small screw underneath
Mike
LinTeal
« Reply #4 on: August 05 2021, 09:58 »
Many thanks.I didn't notice a button or a screw.I will look again next time I am at the boat and if unsuccessful, will post a photograph.
Jake
  • Boat Model: 44
« Reply #5 on: August 05 2021, 11:52 »
If they are the white plastic lights, there is a button on the bottom to depress while simultaneously rotating the bottom edge towards you.  They don't come apart easily, but once you get the knack, it's not too bad.  I was always afraid of breaking one.  So far none have broken.
Jake
Jake Brodersen
Winedown
Bavaria 44
