Fridge and voltage drop
Author Topic: Fridge and voltage drop  (Read 3403 times)
marioxp
« on: July 10 2021, 11:12 »
Fridge in Bavaria 32 2003 occasionally stops working.
I measured the voltages and noticed that when the refrigerator is running the voltage drops to about 10.5V. The batteries are brand new and the voltage is a constant 12.6V. I checked the cables, and they're fine.
What could be the reason for this voltage drop?
I guess the reason the refrigerator stopped working was the voltage drop.
Re: Fridge and voltage drop
« Reply #1 on: July 10 2021, 12:16 »
Mine used to stop working occasionally.  Traced it to a faulty relay in the switch panel.  Swapped it for an unused one, and all is well.
marioxp
« Reply #2 on: July 10 2021, 12:29 »
Relay?
Did you mean switch?
elias
« Reply #3 on: July 10 2021, 15:19 »
Hi , the voltage drop can be also due to inappropriate wiring . Especially if they run far from the source . I changed mine to 4mm2 cross section for less losses .
« Reply #4 on: July 10 2021, 16:38 »
Relay?
No, I meant relay.  The various circuits on my boat are controlled by relays (the dark grey rectangular things on the circuit board in this pic).
« Reply #5 on: July 10 2021, 17:06 »
Either the cables are undersized, or they aren't fine. Often the fault is at the crimped connectors when moisture causes corrosion which causes high resistance. Check again.
marioxp
« Reply #6 on: July 10 2021, 18:24 »
Wire is 6 mm2, it is 5-6m long. I changed connectors with brand new..
We noticed that when pump of electric toilet run voltage drop even more, voltage on battery drop negligible.
« Reply #7 on: July 11 2021, 16:00 »
Is the wire itself corroded (copper gone brown/green on untinned wire)?
10.5V is where the fridge controller switches off by default to protect batteries from deep discharge.
GeoffV
  • Boat Model: Bav 37 Cruiser
  • Boat Year: 2016
« Reply #8 on: July 12 2021, 09:25 »
I have a similar problem with a relay - can they be replaced?
« Reply #9 on: July 12 2021, 11:13 »
Yes, they just plug in to the circuit board.
GeoffV
  • Boat Year: 2016
« Reply #10 on: July 12 2021, 13:58 »
…… and finally, a supplier? :-)
Thanks.
« Reply #11 on: July 12 2021, 14:53 »
Thanks.
Don't know, I just swapped the dodgy relay with one on an unused circuit.  There'll be some sort of part number on the relay, so it should be easy to find a replacement.
« Reply #12 on: July 12 2021, 15:54 »
Try CPC Farnell,  (sales@cpc.co.uk) with the serial number of the relay in question.
Also, do any of the crimped terminals get warm/hot when powered up?....they shouldn't.......Bill.
