Cracked fuel tank D150 - bavaria 38
Bavaria Yacht Info
The FREE Bavaria Yacht Forum
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Login
Register
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Cracked fuel tank D150 - bavaria 38 (Read 5529 times)
Tikitikitwo
Swab
Boat Model: Bavaria38
Boat Year: 2003
on:
June 25 2013, 12:59 »
the tank has a small crack, 5 cm long, on the lateral side at the smaller end, where there is the filler pipe.
Any advise on how to repair it is welcome?
many thanks
Maurizio
Logged
R.I.P.
Old Salt
Boat Model: Bavaria 47
Boat Year: 2000
Re: Cracked fuel tank D150 - bavaria 38
Reply #1 on:
June 26 2013, 07:12 »
What is that tank made of? If plastic, you can weld it; look on eBay for plastic welding.
Logged
Tikitikitwo
Swab
Boat Year: 2003
Reply #2 on:
June 26 2013, 20:43 »
thanks.
It seems PE
Logged
Spirit of Mary
Able Seaman
Boat Model: Bavaria 38
Boat Year: 2003
Reply #3 on:
July 03 2013, 21:57 »
Tanks, water and fuel, are made of PE. PE can only be repaired by welding. I repaired my water tank (cut of 10 - 15 cm) by welding and adding fresh PE material for filling the cut. The heater should have a narrow tip for right precise dosing of the heat.
Ger
Logged
Tikitikitwo
Swab
Boat Year: 2003
Reply #4 on:
July 03 2013, 22:52 »
did you use a soldering heater or a hot air heater?
Maurizio
Logged
Spirit of Mary
Able Seaman
Boat Year: 2003
Reply #5 on:
July 05 2013, 22:03 »
I used a professional hot air heater, which I could borrow from the company where I worked. I guess it could be possible with a hot air paint stripper with an additional special (DIY?) narrow nozzle.
Gr,
Ger
Logged
Print
Pages: [
1
Go Up
« previous
next »
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
