Cruiser 37 2006, Plumbing Dimensions
Author Topic: Cruiser 37 2006, Plumbing Dimensions  (Read 2166 times)
umu
« on: May 15 2021, 18:23 »
I want to replace the Thru-Hulls/Ball Valves/Hose Nipples on my 2006 Bavaria 37.
She is currently stored far away and I need to bring the stuff in from home so I was wondering if someone still has a note with the dimensions around and could
kindly verify:
1. Saildrive
I found a post for the 120: 1/2" Valve, 3/4" (19mm) Hose ID.
It it identical on the 130?
2. Galley Sink drain
My guess Is it is a 3/4" ID Hose and 3/4" Valve, but not sure, could also be 1/2"/1/2"
3. Heads
Sink Drain is same dimensions as Galley?
And Toilet Water intake same as Drain?
Black water outflow I could verify to be 1 1/2" Valve/38mm ID hose
Thanks a lot!
paulemeier1
Re: Cruiser 37 2006, Plumbing Dimensions
« Reply #1 on: May 16 2021, 14:33 »
can confirm ;
Toilette intake is 3/4" Valve and 3/4" Hose
Black water outflow  1 1/2" Valve / 38mm ID hose
just done the job 4 weeks ago  ;D
i am pretty sure galley and sink drain also 3/4"
umu
« Reply #2 on: May 20 2021, 17:30 »
Great, thanks for that!
Anybody around who knows the dimensions of the Saildrive Valve on the 130S and ID of the Engine hose ?
can confirm ;
