Algae in fuel tank
Author Topic: Algae in fuel tank  (Read 2908 times)
marioxp
Algae in fuel tank
« on: April 30 2021, 15:00 »
At last service I have noticed black particles on fuel prefilter.
I pumped out all diesel fuel (120-130L).
On most lower part of tank I've noticed algae, with pump (soak) and with foam brush on long stick I cleaned everything up. I poured a small amount of diesel a few times and everything soak up.
Obviously, algae formed in the reservoir over the winter.
All diesel fuel i pump through inline filter in to tank.
Is this procedure that I did enough?
Is there anything else I need to do?
Re: Algae in fuel tank
« Reply #1 on: April 30 2021, 16:04 »
I always add biocide every time I add fuel to the tank.
marioxp
« Reply #2 on: April 30 2021, 19:25 »
Which biocide you use?
« Reply #3 on: April 30 2021, 20:34 »
I use Marine 16 Diesel Bug Treatment - https://www.marine16.co.uk/fuel-treatments/dbt
fjoe
  • Boat Model: 30 cruiser
« Reply #4 on: May 01 2021, 08:22 »
Iam am using GTL instead of Diesel plus Grotamar biocide.
diverphil
  • Boat Model: 33 cruiser
« Reply #5 on: May 01 2021, 12:02 »
we put in marine 16 in October 20, made it to the boat last weekend, did a tank check and changed filters, all came out clean.
« Reply #6 on: June 06 2021, 05:45 »
I used Marine 16 throughout the ten years that I owned my B36(2002), and never had any problems with the dreaded fuel bug. I did also make up a fuel polishing system which is housed within a motorcycle pannier box to make it easily transportable, and which is now redundant having sold the boat. So if anyone wants a ready made fuel polishing system, I’ve  got one that is ready to go along with some spare filters and all for £150 plus postage.
fjoe
« Reply #7 on: June 07 2021, 12:44 »
We are using GTL plus a biocide (Grotamar): Braces and belts,
