Single handed rudder extractor
Author Topic: Single handed rudder extractor  (Read 2963 times)
elias
« on: March 19 2021, 20:56 »
I ve just used this setup for taking out and back in my rudder alone .
The system consists us in photo and cost around 15€ . A M10 , 1m long thread bar (normal steel), some nuts and a pad eye, a frame and some dyneema rope . I can lower and raise the rudder for greasing the bearings alone !
Re: Single handed rudder extractor
« Reply #1 on: March 21 2021, 11:51 »
Nice, although you must've gotten tired of spinning that nut! :D
Careful where you grease, especially if you have the roller bearings. Jefa has detailed maintenance instructions and a video: https://www.jefa.com/maintenance/maintenance.htm
https://www.youtube.com/watch?v=xF9OXOCrE5c
elias
« Reply #2 on: March 21 2021, 19:49 »
Is about a 10’ try to take it to the ground ... I just lower it so the upper bearing is free so I can grease it - yes I installed both bearings from Jeffa and they were clear not to use grease inside . Then I move from below the rudder so the lower bearing rolls a little and I apply grease with my finger and a milkshake straw , just to keep it moving a little .
It was tougher without the extractor to put it again even with 3 friends helping, with this nut and bolt it comes slowly but steady up while is controllable routed .
