bav 41 fresh water lines in engine compartment
Author Topic: bav 41 fresh water lines in engine compartment  (Read 2116 times)
aquapore
  • Boat Model: bavaria 41
« on: February 08 2021, 20:21 »
I recently removed and replaced my d2-55 motor and found a blue water line with a closed off fitting which
I don't remember coming across when removing the motor.
Can anyone assist with the function and proper connection of this line. See photo attached.
regards
Aquapore
Re: bav 41 fresh water lines in engine compartment
« Reply #1 on: February 08 2021, 20:31 »
We have similar 'dead end' close to calorifier, looks like factory fitted. Maybe reservation for some add-on equipment, but can'really come up with any sensible use.
BR
Tommi
s/y Anniina (B40 2001)
« Reply #2 on: February 09 2021, 11:16 »
Where is it going?
Might just be a drain point for winterizing the fresh water system.
« Reply #3 on: February 09 2021, 11:47 »
Good point on winterizing Yngmar- on our boat it is on pressure side of cold water plumbing and at the lowest point, so draining from there you should have most of the water out.
Tommi
s/y Anniina
aquapore
« Reply #4 on: February 09 2021, 21:05 »
Thanks all for you insights.  Australia we never think of winterising!
Regards
Aquapore
Robert Wechsler
