does any one know what this is?
Author Topic: does any one know what this is?  (Read 2090 times)
aquapore
  • Boat Model: bavaria 41
« on: October 20 2020, 09:47 »
My DA55 motor has this yellow solid crude lifting the paint on the water pump (primary fluid circuit)
It may be related to a leak of the green coolant?
If the case is aluminum then it I don't know of a yellow aluminium based corrosion product
If is is a corrosion product I would like to known.
Regards
Aquapore
Re: does any one know what this is?
« Reply #1 on: October 21 2020, 03:22 »
Perhaps it is a yellow chromate priming paint. Do you have a photo of the area that you can share so that we can see exactly what it is that concerns you?
