Vibration in reverse gear
Bavaria Yacht Info
The FREE Bavaria Yacht Forum
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Login
Register
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Vibration in reverse gear (Read 2831 times)
Cabtrack
Cadet
Boat Model: 33 Cruiser
Boat Year: 2005
on:
October 04 2020, 22:33 »
I have a vibration in reverse gear. In neutral forward and reverse increasing revs, no vibration. No vibration in forward gear. Any thoughts. Time motor is a Volvo MD2020 and a 130s sail drive with 3 blade folding prop.
Logged
PEA-JAY
Able Seaman
Boat Model: B-Cruiser 39
Boat Year: 2005
Re: Vibration in reverse gear
Reply #1 on:
October 05 2020, 06:47 »
Did this just happen suddenly?
Have you just done some work on the sail drive and this vibration started?
Have you hit something or caught a rope?
Logged
Administrator
Boat Model: 40 Ocean
Boat Year: 2001
Reply #2 on:
October 05 2020, 11:24 »
The most likely culprit is the folding propeller. Hop in the water and check for fouling growth and stuck debris.
Logged
(formerly)
Sailing Songbird
⛵️ Bavaria 40 Ocean (2001)
Cabtrack
Cadet
Boat Year: 2005
Reply #3 on:
October 06 2020, 10:09 »
Hi Pea-Jay I recently changed out the rubber diaphragms on the sail drive.
Logged
PEA-JAY
Able Seaman
Boat Year: 2005
Reply #4 on:
October 06 2020, 11:01 »
If this problem happened soon after the diaphragm job make sure you reassembled the bearing housing in the drive unit using 8 x 25 bolts VP ref 946541 and not slightly longer ones
If you inadvertently used longer ones they will bottom in the threaded holes and you will think that they are fully tightened. On engaging reverse the bearing housing will move away from the lower unit and you'll have play on the shaft.
Have you found any oil contamination from sea water ingress?
Logged
Cabtrack
Cadet
Boat Year: 2005
Reply #5 on:
October 06 2020, 11:11 »
I used all the bolts that came out, no new ones and the oil is perfect.
Logged
elias
Old Salt
Boat Model: Bavaria 44
Boat Year: 2003
Reply #6 on:
October 06 2020, 14:25 »
Had same issue
Check post
Vibration while reversing - Volvo saidrive 120 - engine penta 55
Logged
Cabtrack
Cadet
Boat Year: 2005
Reply #7 on:
October 06 2020, 21:01 »
Hi Elias
Thanks for the information and will just monitor the situation. You haven’t had any issues since?
Logged
Print
Pages: [
1
Go Up
« previous
next »
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
