Bavaria 34 antifoul
Author Topic: Bavaria 34 antifoul  (Read 2648 times)
Smeaks
Bavaria 34 antifoul
« on: September 22 2020, 20:21 »
I am planning my year end lift.
How much antifoul does it take to fully AF a 2002 Bavaria 34?
Re: Bavaria 34 antifoul
« Reply #1 on: September 22 2020, 20:50 »
5 litres of International Micron would be fine, and should last 2 years in the water.
Clivert
« Reply #2 on: September 23 2020, 16:56 »
We've used Tiger Extra for the nine years we've had ours and we've had no problems.
Antifouled in April last year ( putting Extra around the waterline )and we had our first sail this year over last weekend and still able to get great boat speed.
Smeaks
« Reply #3 on: September 29 2020, 17:00 »
thanks all
Baddox
« Reply #4 on: September 29 2020, 21:39 »
Don’t paint the antifoul on yet if you’re getting lifted out for the winter.  Instructions on the tin will guide you as to the maximum time it can be left before relaunch.
You may also want a special AF for your propellor and also the sail drive if fitted.
« Reply #5 on: September 30 2020, 07:17 »
Be sure to use an aluminium friendy antifouling paint on your sail drive, aluminium propeller if fitted and the aluminium part around the rudder shaft. Do not use copper based antifouling, such as that used on the hull, on any aluminium parts as this could cause rapid corrosion of the aluminium. Using copper based antifouling paint on aluminium parts could be a very expensive pain in the pocket !!!
