engine oil lands in bilge
Author Topic: engine oil lands in bilge  (Read 2346 times)
aquapore
  • Boat Model: bavaria 41
« on: September 13 2020, 08:08 »
I have a Bav 41 with Volvo d2-55 engine.
I have just discovered the entire engine oil in the bilge under the motor.
The boat has been sitting idle for about 8 weeks.
It may be a corroded sump.
Never seen an oil leak before
We do get some rain water coming in.
Is this a known issue with these motors.
I will investigate further.
Appreciative any comments.
Re: engine oil lands in bilge
« Reply #1 on: September 13 2020, 12:03 »
Pour some oil in and see where it comes out?
Some engines have a drain plug on the sump from their other life as car engines and that might've just come off.
aquapore
« Reply #2 on: September 14 2020, 03:30 »
Thanks - I am cleaning up the mess. I will check that. No sense in being pessimistic.
However, I am unable to see but it feels like sandpaper.
Does anyone have experience in removing and replacing the sump.
PEA-JAY
  • Boat Model: B-Cruiser 39
« Reply #3 on: September 14 2020, 06:33 »
Hi. For all the oil to leak into the boat it must be a leak from below the sump gasket. My D2-55C is fitted with a drain pipe to facilitate oil extraction from the lowest point. There might be a leak were it connects to the sump. Ideally you need to measure how much oil leaked. The engine including the oil filter takes close to 10 litres.
