Removal of Bavaria ocean rubbing strake/ rub rail
Author Topic: Removal of Bavaria ocean rubbing strake/ rub rail  (Read 2586 times)
Jam
« on: August 22 2020, 00:57 »
Yngmar has already given a good description of this task to seal the the hull deck joint.  I also had trouble removing some of the very long screws with a good fit pozi bit and decent drill.  A few broke and some heads were rounded, made a few holes in teak larger than I would have liked so will  need to fill later.
The remaining few that had there heads rounded came our well with a later purchased screw extractor set called easy out.  I was doubtful it would work with SS screws but they came out no problem, wish I had bought it before I started.
You may want to consider this if you are having trouble or are about to remove the rubbing strake/rub rail
John
