o rings for speed/ temp sensor
Author Topic: o rings for speed/ temp sensor  (Read 2804 times)
diverphil
  • Boat Model: 33 cruiser
« on: August 03 2020, 19:48 »
hi, does anyone know the part number or where I can get replacement o rings for an air mar speed/temp sensor The part number on top of the sensor is 20-399-01 I've tried svb and they cant help.
attached is a pic of it,
regards
Phil
SorinCT
  • Boat Model: Bavaria C36
Re: o rings for speed/ temp sensor
« Reply #1 on: August 04 2020, 06:14 »
O-ring sets may help. Next tine you pull it out measure OD and thickness. Should match up with something from the set or you can find some misc seals on the web. It's a static seal so not so critical on material (viton, gp rubber, etc). Have a look at the plug for reference.
Rampage
« Reply #2 on: August 04 2020, 11:53 »
Best bet is to remove the sensor and measure the o ring and then go here https://simplybearings.co.uk/shop/All-O-rings-and-kits/c4747_5572/index.html?page=1 and buy the o ring to match.  You’ll need a micrometer to measure internal diameter and the diameter of the ring material.  Very good service from these folks in the past in terms of delivery.  As already said, no need to worry about what the rings made of, just find one that matches for size.
I usually buy a slightly smaller one, one to the size I measured and a slightly larger one in case of measuring errors.
diverphil
« Reply #3 on: August 06 2020, 06:30 »
will have a measure up of the ones on the plug next time i go down.
thanks
phil
« Reply #4 on: August 06 2020, 09:30 »
Search eBay for Airmar spares, have to get impeller as well.
