Bulkhead sealant
Author Topic: Bulkhead sealant  (Read 2335 times)
Ykmountie
Bulkhead sealant
« on: June 30 2020, 00:07 »
Hi, I have a Vision 42 and need to change a Nav light. I am wanting to know if there is an easy way to remove the sealant around the wires in the anchor locker ? Any help is appreciated.
Re: Bulkhead sealant
« Reply #1 on: June 30 2020, 10:35 »
What sealant is it? Ours was some flexible white adhesive sealant, which meant the only way to remove it is with a knife. Careful you don't injure the cable.
« Reply #2 on: June 30 2020, 11:52 »
Not sure why you need to disturb the wires inside the boat just to replace the nav light. The connections for the light are inside the light itself.
