Sudden shift to lower RPM
Author Topic: Sudden shift to lower RPM  (Read 5868 times)
Remrio
  • Boat Model: Bavaria 46 Cruiser
« on: June 18 2020, 02:17 »
I am hoping someone here might be able to provide some light on my issue.
I have a 2008 Bav 46 Cruiser with a D2-75 engine with a turbo.  The turbo was completely rebuilt in Nov. 2019 as condition of sale to me.  I sailed her 30 miles from Annapolis to my marina in Rose Haven, Maryland after taking delivery.  She stayed in water over the very, very mild winter.  No freezing, no issues.
I sailed her once only since then and only under engine just two weeks ago. Everything started as normal.  An hour into my sail, I increased speed to just below the upper end of her ability.  She didn't quite respond as expected.  After approximately two minutes, she automatically and without any action by me, shifted down to a lower rpm while the shifter stayed at the higher rpm level I initially placed it at. I repeated this process three or four times before leaving her be so as not to push my luck.
This is an extremely clean and well maintained engine with less than 500 hours on it. Any ideas of what the issue could be?  Any insight would be appreciated.
Re: Sudden shift to lower RPM
« Reply #1 on: June 18 2020, 06:02 »
To my experience and based on what I have read around, by far The most common cause of all rpm problems is fuel problems. Have you changed / inspected filters, and the possibility of dirt or diesel bug on the tank?
BR,
Tommi
s/y Anniina
elias
« Reply #2 on: June 18 2020, 06:15 »
I agree with Tommi,
The most common fault around my sailing neighbourhood is fuel issues after winter rest , check the filter, eye inspection through the glass pot of fuel water separator ( mud/slime )or open the tank lid and inspect , even if you change the filter and the tank is  dirty the problem will repeat after healing while sailing. Else is something more complex than dirt
SorinCT
  • Boat Model: Bavaria C36
« Reply #3 on: June 18 2020, 06:15 »
As a first start by checking all linkages for the fuel pump levers, maybe also verify throttle arm has no slip on cable jackets. If control side is ok next suspect would be fuel delivery (contaminants or air) which would determine faulty operation of fuel injectors. A sudden drop of rpm with no smoke or noise would not tipically happen due to a faulty turbo. You could have a look at the air intake though....
PEA-JAY
  • Boat Model: B-Cruiser 39
« Reply #4 on: June 18 2020, 07:22 »
Check you fuel tank air vent before you touch anything else! I think you probably will find it blocked. Otherwise next time it happens try opening your filler cap. Raph.
« Reply #5 on: June 18 2020, 07:51 »
Change the primary fuel filter
Domi409
  • Boat Model: B45
« Reply #6 on: June 18 2020, 11:11 »
Fuel is very common and it gets worse when the fuel tank is not topped up completely during winter as condensation will easy bug growth and water at the bottom of the tank. Checking fuel filter and pre filter will help sorting the issue.
Klausen
  • Boat Model: Bavaria 37 cr
« Reply #7 on: June 18 2020, 13:36 »
Diesel-Bug?!!!
« Reply #8 on: June 18 2020, 14:31 »
Diesel-bug = microbiological growth (algae, bacteria) on modern diesel bio-components when water and air are present. This growth can appear as slime or cloudiness and will block easily filters and on severe cases even fuel lines / valve / transfer pump.
BR,
Tommi
s/y Anniina
« Reply #9 on: June 18 2020, 23:28 »
Have a look at the following You Tube clip.
This explains most of the diesel bug problems I have seen in Bavarias. Your Off/On switch is probably partially blocked.
https://www.youtube.com/watch?v=GS86BsbisNc&t=201s
Your filters are probably OK.
« Reply #10 on: June 21 2020, 15:17 »
Although the suggestions above concerning fuel supply are logical, my experience is that in such cases the engine either turns off completely after some time or starts to rev up and down arbitrarily. I do not remember a case where it  stayed at a constant lower RPM.
Another option, although it should have happened immediately when trying to rev up and not after some time, is a blocked exhaust mixing elbow - after 500 hours this is something that may happen if the elbow was never cleaned. A common sign for this is when you start the engine you see a gray circle of soot on the water surface at the exhaust outlet.
diverphil
  • Boat Model: 33 cruiser
« Reply #11 on: June 21 2020, 16:57 »
hi, when you say tried it a few times, does that mean lower revs for a while with the throttle moved to a lower setting, then its ok , then when you increase revs its ok for a few minutes but then dies down again on its own without you moving the lever, if that's the case then I would go for fuel starvation as the cause. at any of the points it could block up , pick up pipe, fuel tap, pre filter, main filter.
are there any other signs of things not quite right with the engine, i.e. running hotter than normal as this would point to the exhaust elbow blocked causing lack of air going into the engine that would also show in the colour of exhaust gas. black smoke due to over fuelling as the air cant get in if the exhaust cant get out.
cegri
  • Boat Model: Bavaira 39C
« Reply #12 on: June 17 2024, 13:07 »
Has anybody had an air ingress problem with the fuel pickup tube at the tank? (see picture)
I was also having some sudden RPM loss problems lately. Checked all the ussual suspects on the fuel line. No improvement. But I realised the pickup tube did not make a very tight fit into the elbow. Wrapped a few rounds of teflon for a tighter fit.
The problem seems to have gone away. As it was very inconsistent, I'm not celebrating early. I'm wondering if anybody else had this problem.
Diverphil1
  • Boat Model: 33c
« Reply #13 on: June 17 2024, 18:06 »
sounds like fuel starvation, check filters ,and check pipes are cleat, the on\off tap is a likely place to block.
cegri
« Reply #14 on: June 17 2024, 21:20 »
"I have checked all the usual suspects"; filters, hoses, the valve...
Only after improving the fit of that pickup tube that the problem went away.
GeoffV
  • Boat Model: Bav 37 Cruiser
  • Boat Year: 2016
« Reply #15 on: June 19 2024, 09:57 »
I think that is a common problem with Bavarias - so stated the mechanic who found and cured my lower revs drop recently. He said its  something to do with the way the gas tap that Bavaria fits is designed that causes the reduction in fuel flow as it slowly blocks.
Anyway its on my to do list for this winter to swap out for a proper fuel on/off tap.
« Reply #16 on: July 10 2024, 13:16 »
I'd agree with Lyra and check the exhaust mixing elbow. After 500 hours it is most likely the issue.
