Boat speed
Author Topic: Boat speed  (Read 2780 times)
Alphadug
  • Boat Model: Vision 42
Boat speed
« on: June 09 2020, 00:30 »
This is probably an impossible question to answer but I'm looking for ideas/information. I have a 2015 Vision 42 with a D2-40 and a 130S sail drive(2.19 ratio) swinging an 18x12 3 bladed folding prop. From what I can find on the forum and Volvo's website the prop should be 18x13. I haven't tried a full throttle run without a 12' RIB behind me. Next time we go out I will. We run around 2700 RPM. Towing the RIB we have never hit 8Kts. Theoretical hull speed is around 8.5. At the moment my speedo is reading way too high (2Kts above GPS) so is a useless number until I calibrate it on the next trip. Now for the question. Does anyone have the same boat and what speed do they get? Or, what do you think I should be able to get out of this setup? I'm not going to buy a new prop for a half-knot gain but might run at higher RPM if it's not too noisy and rough. 2700 RPM is very smooth and quiet and the mechanic says it will be happy running at higher revs. I boat in an area with big tides and big currents so a little extra speed can be useful at times.
Thanks,
Doug, S/V Vivia
Re: Boat speed
« Reply #1 on: June 09 2020, 07:46 »
On a 42 with a 40hp engine, I would be surprised if you managed to get 8kts in anything but ideal conditions.
I would expect the boat to cruise at 6.5-7kts at about 2500 rpm.  After that you will use a lot of power to get small increases in boat speed.
Re: Boat speed
« Reply #2 on: June 09 2020, 10:49 »
It is not possible to achieve hull speed with only 40hp. The best you are likely to see is perhaps 7.8 knots. This is primarily a function of weight - 10 tonnes+ needs closer to 50hp. The optional D2 55 is a much better choice for this boat and would give a speed of around 8.75 knots.
However, you have to work with what you have. First thing to check is your engine rpm and actual speed at full throttle in flat water. The engine is rated at 3200 maximum and you would expect a correct prop size to achieve at least 3000, hopefully higher. As I explained in reply to Winga below, 1" of pitch change leads to a change in engine revs of 250-300 so given propellers come normally in 1" increments it is difficult to get exactly right, but you need to be able to access maximum power so aim to get as close to 3200 as possible. Normally this engine/drive combination would have a 17" propeller, but going up an inch in diameter is a good thing when you are marginal on power. I suspect that 12" pitch is already on the coarse side and certainly moving to 13" would not be a good idea as it would limit engine revs and lead to a lower maximum speed, although the trade off would be lower cruising revs for a given speed.
Carry out your speed test (make sure the hull is clean) and if you get over 3000 rpm and around 7.8 knots then you have got the best you can. If the maximum revs are below 3000 and speed below 7.5 knots then there might be value in going down 1" in pitch. You can buy just a blade set which should be much cheaper than a complete propeller.
