2002 Bav 40 bulkhead thickness
Author Topic: 2002 Bav 40 bulkhead thickness  (Read 3670 times)
MagicalArmchair
  • Boat Model: Bavaria
« on: November 16 2019, 22:05 »
In a bid for movie nights on board with the kids, we are fitting a television on the main bulkhead, with a bracket that it can swivel out.
I figured the bulkheads were 12mm/14mm ply? I'd prefer to bolt it through, but that would involve drilling into the heads, so I figured six beefy self tappers would do the job well enough, ground down to the correct length.
Is 12mm the correct thickness of that bulkhead?
Jeff Jones
Re: 2002 Bav 40 bulkhead thickness
« Reply #1 on: November 16 2019, 22:14 »
check thickness at the door frame, mine is minimum 3/4" thick maybe 20mm thick ply
« Reply #2 on: November 17 2019, 08:38 »
The ply is 19mm thick.
MagicalArmchair
« Reply #3 on: November 17 2019, 08:46 »
Perfect, thank you.
« Reply #4 on: November 17 2019, 13:21 »
Yes, use No 8 or 10 stainless pan head screws with a suitable pilot hole. The thickness of the bracket plate will make sure the screw does not break through but only drill your pilot hole 15mm.
« Reply #5 on: November 17 2019, 17:03 »
If you're using a 'swing out' TV bracket best to make sure you can secure the TV firmly against the bulkhead when underway, as the heavy TV could cause a lot of damage if it's allowed to get loose and swing about in a seaway, not least to itself........Bill
MagicalArmchair
« Reply #6 on: November 17 2019, 20:37 »
Thanks Bill, yes we are using a bracket with a substantial locking mechanism.
Thanks for all the tips!
