Battery Alarm when engine start...
Author Topic: Battery Alarm when engine start...  (Read 2859 times)
Kala
« on: October 07 2019, 22:21 »
Hi all... I'm going to need your help again!..
When I start the engine (Volvo md2030, BAV36 2002) the battery alarm lights and buzzes as hell until I move throttle ahead (disengaged) as soon as it gets revs, the alarm stops... Do you know what`s going on?
Thanks!
Re: Battery Alarm when engine start...
« Reply #1 on: October 07 2019, 23:14 »
Just the alternator not waking up until you get a bit of revs on. Might be worth getting the alternator checked out particularly if it is the original nearly 20 years old.
« Reply #2 on: October 08 2019, 03:48 »
Thanks!
Probably the engine idle speed set marginally too low.
My MD2020D from 2002 also does the same unless when I start it in neutral I keep the neutral button depressed and just move the throttle slightly to get a few more revs. Then the battery charging alarm doesn’t sound at all. Personally I prefer to hear the alarm so that I know it’s working, then I move the throttle while retaining the prop disengaged for a few moments before returning to its idle speed and the alarm then remains silent.
Kala
« Reply #3 on: October 08 2019, 06:50 »
Thanks Salty and Symphonie!
Quote
That's exactly what I do..
