Vision 46 cockpit table not working.
Author Topic: Vision 46 cockpit table not working.  (Read 4243 times)
Boomerang
  • Boat Model: Vision 46
  • Boat Year: 2016
« on: August 14 2019, 11:16 »
Our cockpit table will not lower when we press the button on the helm. Not sure if it is an electrical issue with the table itself or whether it is the fuse. We don't know where  the fuse is for the table so can't check this first before tearing the boat apart looking or the fault if not fuse.
Please advise on fuse as well as frequently reported issues on this which may shorten the work to rectify.
Jonathan
captbrad
Re: Vision 46 cockpit table not working.
« Reply #1 on: November 29 2021, 20:55 »
Wondering if you ever resolved this problem. My Vision 46 has same problem that I have yet to resolve.
paulemeier1
« Reply #2 on: November 30 2021, 10:48 »
last activity 2018/08
Thomas
  • Boat Year: 2012
« Reply #3 on: February 10 2022, 16:37 »
It happened to my 46 too
A couple of options
1 defective controller which is situated in the lazerett near the shore powered cut out
Or
The wire drive motor has seized as water has goy into the table leg. There is no drain hole to let it out and the motor sits in the water.
I took the whole table to pieces by unscrewing it  from the cockpit floor.
As usual Bavaria were no help at all.
Replaced it with a manual system
Porquerolles
  • Boat Model: Bavaria 42 Vision
  • Boat Year: 2019
« Reply #4 on: February 12 2022, 10:16 »
Bonjour Thomas,
Je suppose que c'est de l'eau douce,
comment est-elle rentrée dans le pied de la table ?
Bien cordialement.
Thomas
  • Boat Year: 2012
« Reply #5 on: February 12 2022, 11:27 »
The table leg is made of aluminium tubing. The smaller diameter slides inside the larger as the table goes up and down.
This is not water proof and water can get in when washing the boat.
There is no drain hole together it out.
The motor is a long thin worm drive which  eventually gets too wet to work.
The table is not hydrolic it works by the worm drive expanding and contracting pushing the table up and down.
Porquerolles
  • Boat Year: 2019
« Reply #6 on: February 12 2022, 19:59 »
Merci beaucoup pour l'information. J'étais persuadé que les tubes étaient étanches …. dorénavant, je vais faire très attention en lavant le bateau !!
Sunharvester
  • Boat Year: 2016
« Reply #7 on: February 18 2022, 13:16 »
I had same issue with my manual table. Lube helped.
I also have an issue with table not properly fastened to base.  Its loose and wiggles. Previous owner slapped a bolt and nut so it doesnt lower proper.
Can anyone post a pic or explain the factory connection between base leg and table?
It must be a flush connection so the table lowers proper.
jmarshall
  • Boat Model: Vision 42
  • Boat Year: 2016
« Reply #8 on: April 19 2023, 05:01 »
I contacted Barka, the Italian manufacturer of the electric pedestal. They sent me some schematics of the pedestal. My pedestal base has a fifth screw holding a small aluminum “cup” with a drain slot. Barka said this is a Bavaria add on and not supplied by them.
jmarshall
  • Boat Year: 2016
« Reply #9 on: April 19 2023, 05:04 »
Another schematic…
