Rainwater in standing in the companionway hatch grooves - 2005 36' Cruiser
Author Topic: Rainwater in standing in the companionway hatch grooves - 2005 36' Cruiser  (Read 3180 times)
Harveyhall
After throughly chalking the companionway hatch cover, I am still unable to prevent rainwater from accumulating and running into the cockpit from the hatch groves.  I have only found one reference in Bavaria Yacht Info to this problem. Have other owners found this a problem and have you been successful in preventing the rainwater from running onto the cockpit floor?
Harvey
I have tried fixing this over the years, but only get a tempary restbite. I also have resealed the plate, especially the aft end by the spray hood, also used  crack sealer, and sealed the Channel with foam, but it still leaks water.
So anyone out has ACTUALLY fixed this problem let us know.
p_schurli
  • Boat Model: 40
The water gathers in the grooves of the companionway sliding cover. I have simply put some sikaflex into these grooves. Now the water cannot run into the cockpit floor. Ofcourse I have some standing water in the forward part of the grooves. But no more than 1mm.
Bavaria 40 <Novara>
Is your boat balanced fwd/aft? By design, the water should run out of the front drain channels under the sliding hatch garage, at least on our 40 Ocean. If the boat is however much heavier in the stern than in the bow, it will run the wrong way. Put more anchor chain in the bow!  :))
