Bavaria 2000 model teak deck stanchions - source?
Author Topic: Bavaria 2000 model teak deck stanchions - source?  (Read 3218 times)
jdy66
  • Boat Model: Bavaria 42
« on: August 09 2019, 01:14 »
This forum has been incredibly helpful at helping me track down the source of leaks into the cabin, which turned out to be stanchion bases and also the perished sealant in the hull/deck joint.  The boat is a 2000 model Bavaria 42 Cruiser with the teak deck/side strips.  One thing I am stuck on is sourcing replacement stanchion bases such as the attached.  SVB24 etc don't seem to stock them and I am wondering if anyone had found a source for these? You can see from the pic why these are needed! One alternative would be to straighten them or have them made up, I guess.  Thanks!  Jon
Re: Bavaria 2000 model teak deck stanchions - source?
« Reply #1 on: August 09 2019, 07:29 »
No need to replace them, every metal working company can straighten them for less money
« Reply #2 on: August 09 2019, 07:45 »
Easily straightened. Save your money.
« Reply #3 on: August 09 2019, 09:12 »
Put a few nuts on the threaded part, clamp in a vise, stick the stanchion over the other end and pull until straight.
jdy66
« Reply #4 on: August 09 2019, 11:56 »
Thanks - I shall give them a go straightening them first.  Wanted to have a source in case one cracks on me but it sounds like there isn't a ready supplier if I need a spare...
Jon
« Reply #5 on: August 09 2019, 12:08 »
as it appears on the photo they can easily machined by by a metalworking company, if really necessary. Seems pretty simple to do on a lathe if you provide a sample  to them.
jdy66
« Reply #6 on: August 10 2019, 02:01 »
Thanks very much - and especially for the 'how to' from Yngmar.  Very helpful.  I'll give it a go next time I am back with the boat (which is sadly a few months from now).  Cheers - Jon
Joe
jdy66
« Reply #8 on: August 29 2019, 11:25 »
Spot on Joe - I've now matched up the measurements and this looks perfect.  They are now on order!  Much appreciated.  Jon
