Saildrive Propeller Shaft Seal replacement
Author Topic: Saildrive Propeller Shaft Seal replacement  (Read 2618 times)
Jeffatoms
  • Boat Model: Ocean 38
« on: July 31 2019, 15:40 »
I am experiencing problems with my 120S-E saildrive.  Sea water appears to have gotten past the two seals.  I'm wondering if we can drain the milky oil and replace the seals with next haulout from the prop area or does the saildrive need to come all the way out of the boat?
Thanks in advance!
Jeff & Sue
S/V Zephyrus
B38 Ocean
Re: Saildrive Propeller Shaft Seal replacement
« Reply #1 on: July 31 2019, 16:36 »
No need to remove the drive. As I explained in your other thread it can be done relatively easily. Remove the end cap of the drive behind the propeller and anode and that contains the seals. It also exposes the shaft so you can check for wear. Doing this automatically results in the oil draining, but it is till worth removing the drain plug at the bottom both to drain the small amount of oil that lies under the shaft, but also because it is difficult to remove if it has been in a long time. You can then replace it so it is perhaps easier to remove if you want to drain the oil in the future.
Google Volvo saildrive oil seal replacement for lots of information and videos. If the shaft is worn then google volvo saildrive shaft sleeves and you will find information on using SKF Speedi sleeves to repair the shaft. Replacing the seals is for some a DIY job, but sleeving the shaft is a workshop job.  Volvo and aftermarket suppliers like Keypart in the UK sell seal kits to do the job. I expect there are aftermarket suppliers in the US and Canada as well.
If there is water in the oil then early investigation and repair is advised!
Jeffatoms
« Reply #2 on: August 01 2019, 03:21 »
Many many thanks for taking time to help a sailor in distress!
Jeff
Clivert
« Reply #3 on: August 01 2019, 20:17 »
Drain the oil first.
Then you'll need an allen key, an extension for leverage and a block of wood to stop the prop turning.
Pretty straight forward after that.
Don't forget to refill with oil to the right level.
Happy sailing ( motoring )
