Companionway rubber inserts
Author Topic: Companionway rubber inserts  (Read 3153 times)
Krill
  • Boat Model: Bavaria 30
« on: July 06 2019, 19:52 »
Where might I find the rubber inserts for the companionway steps?
Boat is a 2006 bav30
Here is a pic (hopefully)
Re: Companionway rubber inserts
« Reply #1 on: July 06 2019, 21:08 »
You could try Clipper Marine at Swanwick, they carry a range of Bavaria odds and bits, don’t know if companionway rubber strips would be included. Your revamp of the companionway area looks good.
Baddox
« Reply #2 on: July 06 2019, 21:50 »
It looks like the stuff some o-rings are made from. You can buy strips of the material to glue into an or-ring, for example https://www.ebay.co.uk/itm/Metric-Black-Rubber-O-Ring-Material-Sold-Per-Metre-1-4mm-To-8-4mm-Thickness/371853949652?hash=item569438fad4:m:mUC7SdVrQR9uguiB5d6VnnQ
« Reply #3 on: July 06 2019, 22:58 »
Is this the stuff? Your photo is rather indistinct.
https://www.svb24.com/en/bavaria-stairs-anti-slip-profile-in-black.html
Krill
« Reply #4 on: July 08 2019, 09:06 »
yes this is it! thank you
expensive stuff :O
