Telescopic spinnaker Cruiser 33. 2014
Author Topic: Telescopic spinnaker Cruiser 33. 2014  (Read 2364 times)
ANTREVELL
« on: June 29 2019, 18:25 »
Would anyone know the length and model of a telescopic spinnaker pole.
Lost my fixed up the mast pole over the side . Would like to buy one pole which would do spinnaker and and pole out the Genoa to goose wing I think mine was a selden
Would still like to keep it up the mast
Regards Tony Revell Pegatha
Re: Telescopic spinnaker Cruiser 33. 2014
« Reply #1 on: June 30 2019, 08:22 »
Here's your choices: http://www.seldenmast.com/en/products/spinnaker_-_gennaker_hardware/telescopic_-_jockey_poles.html
Sizing is easy - the indicated length in spinnaker pole position is your boat's J measure (so it fits inside the forestay when gybing). It can then be telescoped out further to support the Genoa in light airs.
The prices are pretty hefty though!
Jake
  • Boat Model: 44
« Reply #2 on: June 30 2019, 17:03 »
Technically they are usually called whisker poles.  Spinnaker poles are a fixed length and are not adjustable.  Spinnakers put a lot of compression forces on the pole.  An adjustable pole wouldn't cope well with that type of loading.
I've used both the spinnaker pole and whisker pole on my headsails.  With a large genoa, you may want a pole much longer than your J measurement.
I personally prefer Forespar poles, but I'm sure the Selden are fine as well.
https://www.forespar.com/whisker-poles.shtml
Jake
S/V WineDown
Barvaria 44
Jake Brodersen
Winedown
Bavaria 44
