AC Pump Relay Box/Pannel on '17 Vision 42
Bavaria Yacht Info
The FREE Bavaria Yacht Forum
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: AC Pump Relay Box/Pannel on '17 Vision 42 (Read 2828 times)
Nate Feldick
Swab
Boat Model: Bavaria VISION 42
Boat Year: 2017
on:
June 10 2019, 03:01 »
Hello All! My AC pump runs continuously on my 2017 Vision 42. I know its probably an issue with the pump relay switch but after looking at all the usual places, I can't find it. Anyone know where the Pump Relay box/panel may be located? Thanks!
Logged
JJackson18b
Swab
Boat Model: Vision 42
Boat Year: 2017
Re: AC Pump Relay Box/Pannel on '17 Vision 42
Reply #1 on:
July 30 2019, 03:18 »
Curious if you found the answer to this, mine does the same...
Logged
Jon J. SV Ruck-Up
paulemeier1
Able Seaman
Boat Model: Bavaria 37.2 Cruiser
Boat Year: 2006
Reply #2 on:
July 30 2019, 10:43 »
pay attention not to get the hole water from the fresh water tank into your boat.
because it is also passible that there is a leak at a non visible area in your ship so better have a look.
Or the fresh water tank is empty? then the pump also run continuos
Logged
Philipio
Swab
Boat Model: 33 Cruiser
Boat Year: 2006
Reply #3 on:
July 31 2019, 11:44 »
I have a Bav. 33 Cruiser (2006) and the fuel gauge stopped working a couple of months ago. For some reason or other the sender unit was a 3 wire system. On going through the circuitry i found out that the feed for the sender was actually coming via the gauge in the binnacle.Easy to see the spade connections without dismantling everything. Replaced the sender with a new 2 wire system and everything works great now.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
