eberspacher warm air outlet insulation
Author Topic: eberspacher warm air outlet insulation  (Read 2857 times)
filban
  • Boat Model: bavaria 32
« on: June 07 2019, 08:24 »
Bavaria 32 2002
eberspacher airtronic heater
the insulation on the warm air outlet to the cabin needs replacing and I forgot to measure the diameter of the duct pipe whilst on the boat yesterday
I think it is 60mm
can anyone please confirm
thanks
Re: eberspacher warm air outlet insulation
« Reply #1 on: June 07 2019, 11:33 »
Hi filban
I've got an Airtronic D4 and the pipe is 75mm (measured just now, and confirmed in the manual). FYI, manual says Outlet hood sizes are - D2: 60/75mm; D4: 75/90mm so if you think yours is 60mm then that points to a D2.
Hope this helps.
filban
« Reply #2 on: June 07 2019, 11:43 »
thanks very much for your prompt reply
mine is a D2 but the manual is on the boat!
I will order some 60mm dia insulation
« Reply #3 on: June 07 2019, 12:07 »
I think the insulation comes in tubular form which would mean disconnecting an end of the ducting in order to feed the tube over it. You might find it easier to buy a roll of insulating material from, for example, your local plumbers merchant, and simply wrap the insulation around the ducting. It’s what I did, and the difference in warmth within the cabins that it made was quite amazing. Also conversely it meant that much less heat was being wasted from losses within the lazarette and the under bunk areas and other spaces that the ducting passed through that didn’t need to be heated.
