bav 30 cruiser anodes
Author Topic: bav 30 cruiser anodes  (Read 3374 times)
Krill
  • Boat Model: Bavaria 30
« on: February 26 2019, 12:23 »
anyone know the part number for the standard anode on the saildrive?
thanks
Re: bav 30 cruiser anodes
« Reply #1 on: February 26 2019, 16:02 »
Depends on your saildrive model. Model number is on top/rear of the gearbox.
« Reply #2 on: February 26 2019, 16:58 »
There are effectively only two types. Ring anode for 120 drive pre 2005 and split anode for 130 drive. Difference is obvious. Only thing to watch for is if you have a rope cutter for which you will need a modified anode. All shown in Keyparts catalogue, but usually easily available from most chandlers or Volvo dealers. Just for completeness post 2017 drives have a slightly different split anode, but obviously does not affect you.
Krill
« Reply #3 on: February 26 2019, 18:10 »
It’s the 130 and if I recall correctly it’s a split anode in two halves, just want to make sure I order the right thing as it more than likely will be ordered online
« Reply #4 on: February 26 2019, 19:17 »
You can't go wrong if you are sure it is a split anode. Keyparts have them, either genuine or cheaper pattern parts.
Holger
« Reply #5 on: February 27 2019, 00:30 »
VP no. 22651246 (zinc) or 22651247 (magnesium) https://www.marinepartseurope.com/en/volvo-penta-explodedview-7748580-44-7618.aspx
If you want an aluminium anode you have to look for a comatible product.
