Volvo Penta MD-22, TMD-22, TAMD-22 parts
Author Topic: Volvo Penta MD-22, TMD-22, TAMD-22 parts  (Read 7566 times)
« on: February 22 2019, 13:16 »
I am re-powering, so have lots of good parts available from the current motor.  These include:-
Cylinder head complete with new head bolts - £200 - SOLD
4 x Injectors (later 2-stage type) refurbished about 200hrs ago - £100 - SOLD
Injection pump - £25 SOLD
Starter motor - £50 - SOLD
Alternator (60A) - £30 - SOLD
Exhaust elbow (only for TAMD-22) - £50
Coolant pump (brand new kept as a spare) - £75
Raw water pump (Jabsco belt-driven type) comes with spare seal and bearing, and a drive belt. - £50 SOLD
Turbo (TMD-22 and TAMD-22) complete with wastegate casting and actuator. - £50
New cambelt + used but perfectly servicable rollers. - £20 - SOLD
Fuel pump (only seen about 200hrs use). - £20 SOLD
Collect from Oxford, Maidenhead, or Southampton, or I can post at cost.
Re: Volvo Penta MD-22, TMD-22, TAMD-22 parts
« Reply #1 on: February 22 2019, 17:53 »
Woo! I'd like to have:
Injector pump - err, wait, is that the same as on the the non-turbo? Let me check first. Edit: Nope, it's different.
Raw water pump + bits
Fuel pump (assuming that's the lift pump)
The PCV breather valve (brass coloured thing near oil filler)
Tacho (if the hour meter works)
Ignition switch + keys (ours springs no more)
« Reply #2 on: February 24 2019, 14:17 »
Injector pump is the same but needs the warm start stuff moving over to it.
Raw water pump + bits - OK
Fuel pump (assuming that's the lift pump) - OK, yes lift pump
The PCV breather valve (brass coloured thing near oil filler) - Not the brass type, but the plastic one. Fits and works fine, and I'll throw it in FOC for you.
Tacho (if the hour meter works) - Hour meter is intermittent. You can get a repair kit for this.
Ignition switch + keys (ours springs no more) - Ignition switch is only about 5 years old and has 2 keys.
I would like to sell the entire insrument panel with tacho and ignition switch as one item.  Make me an offer for the bits you want, and let's see what we can do.
Bob
« Reply #3 on: February 24 2019, 18:52 »
Thanks, sent you a PM.
Out of curiosity, what went wrong with the TMD22 to prompt replacement and stripping for parts?
« Reply #4 on: February 24 2019, 19:22 »
The engine has done a lot of work, and got to the point where it needed a re-bore as the compressions were down.
In taking the engine apart, I found the heat exchanger and aftercooler corroded to the point where I had to destroy the tube stacks to remove them, and that basically did for the engine, as those parts are more expensive than a new engine.
To anyone with one of these engines, I would advise getting the heat exchanger apart every year just to check for raw water leakage around the o rings.
« Reply #5 on: February 27 2019, 07:51 »
Thanks for the tip Island Alchemy, from current discussion elsewhere within the forum and your recommendation above, getting the heat exchanger apart is going to be next on my list.
« Reply #6 on: March 05 2019, 09:18 »
Only the coolant pump left now.
I'm surprised nobody has bagged this, as they are known to leak and it is recommended that they are replaced along with the cambelt.
It is new and un-used, and I am asking £75, which is half what parts4engines are charging.
« Reply #7 on: March 05 2019, 11:04 »
yes please. Island Alchemy quite poetic really I want it for Alchemy. Geoff Godwin
« Reply #8 on: March 05 2019, 16:42 »
Thanks Geoff.  Have sent you a PM.
All sold now, thanks everyone.
