Bavaria cruiser 42 foot With volvo motor
Author Topic: Bavaria cruiser 42 foot With volvo motor  (Read 3946 times)
russ
  • Live the Dream
  • Boat Model: Bavaria 42 cruiser
« on: February 22 2019, 00:50 »
Hi all, went to my boat today and the rpm gauge not working. Thought i might by a new startimg panel.Does anyone know where i can biy a new panel or rpm gauge?
Re: Bavaria cruiser 42 foot With volvo motor
« Reply #1 on: February 22 2019, 06:57 »
Any generic diesel tachometer taking signal from alternator should work. That is what was my plan, but instead I found out that one automatic fuse had blown causing only tacho to fail.
Jake
  • Boat Model: 44
« Reply #2 on: February 25 2019, 12:17 »
My tachometer has died as well.  I noticed last month that is was reading very low, despite engine rpms being high.  The gauge has some serious condensation in it now and will not function at all.  The hour meter is no longer functioning either.  I may have to investigate the fuse.  Is it located behind the panel or closer to the engine itself?
If I have to replace the gauge, I see Volvo wants $478.00 for one.  I can't imagine what the whole panel would go for...
Jake
2004 Bav 44
Jake Brodersen
Winedown
Bavaria 44
« Reply #3 on: February 25 2019, 17:15 »
The automatic fuses I am referring to were located close to The alternator or a small distribution box o the back Port side of our MD22L engine.
A generic diesel tachometer taking signal from alternator should be well below 100eur even from boat chandler.
BR
Tommi
S/y Anniina
russ
  • Live the Dream
« Reply #4 on: February 25 2019, 23:41 »
Thanks i will check the fuse and dry out the alternator. Thanks
« Reply #5 on: February 26 2019, 11:19 »
If it ends up being the tacho - a fitting generic tacho with hour meter does not seem unreasonably priced at https://www.parts4engines.com/volvo-penta-digital-tachometer-hour-meter/ 73,xx€
Jake
  • Boat Model: 44
« Reply #6 on: February 27 2019, 21:28 »
Yes, that model is reasonably priced.  There's not a lot of technology going on inside.  But it doesn't say Volvo on it anywhere... LOL
Jake
Jake Brodersen
Winedown
Bavaria 44
