2014 CRUISER 33 . CHANGING GAS OVEN
Author Topic: 2014 CRUISER 33 . CHANGING GAS OVEN  (Read 5903 times)
ANTREVELL
« on: February 01 2019, 16:45 »
Hi All
Has anybody changed the existing from new gas cooker. I would quite like one with a grill and better temperature control of the oven.
Wondered if anyone had found a direct replacement . The existing one has not been very good since new . Now only 4 seasons old.
Regards Tony Revell   Pegatha   Cruiser 33
Re: 2014 CRUISER 33 . CHANGING GAS OVEN
« Reply #1 on: February 01 2019, 19:14 »
If you want a grill and oven then height will be a problem as the grill adds around 140mm to the height so the hob will stand well above the worktop. Dimensions are for Dometic cookers which are narrow enough to fit. There is not a direct replacement for the Techimpex already fitted and in my view the best replacement the Neptune (was Plastimo) 2500 is no longer made.
« Reply #2 on: February 01 2019, 20:41 »
If your old cooker was Techimpex the Dometic moonlight 3 is a direct replacement and has a grill  . The only slight change needed is to the gimble mounts . I think that I had to unbend them a bit. The cooker has been in use for I year now and works very well [glass top is easy to clean] Geoff
« Reply #3 on: February 04 2019, 15:57 »
I´ve changed my techimpex to a Dometic moonlight 2 (B46Cruiser 2006) last season. As mentioned by Symphony we  needed to adapt the mounts of the new oven. Works well and my admirality is happy  :)  Robert
ANTREVELL
« Reply #4 on: February 04 2019, 19:53 »
Thank you for our input. Will look at the Dometic.
Regards Tony Revell
Noelio Abrunhosa
« Reply #5 on: February 18 2019, 19:34 »
hi.
I have just changed the cooker this weekend for a Dometic moonlight 2. Jackson leisure supliers have stock at £480 Including next day delivery. it fitted exactly in the same space with no adjustment to gimbals. Gas pipe size is 8mm which is the same as original. but i replaced the compression glands. I had to run a 12 volt supply for the ignitor and oven lamp.
now my roast potatoes get browned  from the grill which is very nice. My BOSS even baked some Portuguese biscuits which were lovely.
Now i understand why she has been nagging about the old cooker since i bought the boat.
Happy cooking
regards
Abby
« Reply #6 on: February 19 2019, 15:34 »
I hope that you can keep your cook (boss!) happy :)
« Reply #7 on: February 20 2019, 10:53 »
Put some photos up, it's an interesting modification.
« Reply #8 on: February 20 2019, 13:03 »
Noelio,   Can you confirm that your,s is a moonlight 2?  From what I gather from the adverts is that only the Moonlight 3 has a grill . Does your galley top close ok like the Techimpex?
« Reply #9 on: February 20 2019, 16:23 »
My galley top closes like the techimpex, but it needs to set the gimbals down (ca. 3 cm). The new oven has the full moving angle like the old one, and it has a grill. See attached picture (the scrambled eggs didnt come with the oven)  :)
« Reply #10 on: February 20 2019, 16:31 »
Syjetzt Thanks for that, I need to double check my width of the worktop opening, my B32 (2003) should be standard width for all Bavaria's, research so far on the internet has not proven that.
« Reply #11 on: February 20 2019, 20:11 »
the direct fit model is moonlight 2 it has grill, glass top and electric ignition, the only change needed is to the gimbles [small reduction in width] . the lid closes normally if the outer leaf is reduced by 10mm Geoff
« Reply #12 on: February 20 2019, 22:57 »
Thanks Geoff,  a bit thrown by your earlier post when you quoted moonlight 3.  Presumably the grill is within the oven,  there only appears to be three controls in the illustrations, two for top, one for oven. When you say reduce outer leaf can you explain “leaf”?
Ps just looked at Dometic site and can only find “ sunlight models also sold at force 4 etc”
« Reply #13 on: February 21 2019, 17:25 »
My cooker cover is in 2 hinged parts, folding out into a worktop. The panclamp support bar on the moonlight 2 just fouled the cover at its folded out position. My solution was a small reduction in one leaf . Geoff
Noelio Abrunhosa
« Reply #14 on: February 21 2019, 19:27 »
hi. the moonlight is not a current model. the only place i foundthat has  old stock is Jackson leisure suppliers still had 7 in stock.
the moonlight 3 has 3 cooker rings
we thought 3 rings on the same size platform is really unusable
regards
Abby
Noelio Abrunhosa
« Reply #15 on: February 21 2019, 19:48 »
the gimbals are about 10mm lower then the stainless edge
