Anchor locker drain holes.
Author Topic: Anchor locker drain holes.  (Read 5220 times)
Boatname
« on: October 21 2018, 15:50 »
Sitting in the marina on our 2001 34 with its unequal height drain holes looking at a new 40 ... with unequal height drain holes and really can’t think of a reason.
Illogical Germans? Surely not  :)
Any idea why?
Ricd
  • Boat Model: 34
Re: Anchor locker drain holes.
« Reply #1 on: October 21 2018, 16:28 »
If they were both of equal height you would have a rust stain running down both sides?  Guess second one only comes into use in extreme conditions?
« Reply #2 on: October 21 2018, 21:13 »
By having one hole lower on one side than the other, almost all of any water that collects in the chain locker will drain out of that one side. Because of this any solid matter, sand, mud, seaweed etc., that you have pulled up with your anchor chain and which you didn’t wash off before it went into your chain locker, will tend to collect on one side next to that lower hole, thereby leaving the upper hole clear to handle those occasions when your boat buries it’s bow into a solid wall of water. If both holes were at the same level, any build up of solid matter within the chain locker would likely block both holes at more or less the same time, thereby allowing your chain locker to fill with water before you had noticed there was a build up that would alter the vessels trim, forcing the bow lower in the water, and which in consequence might endanger your safety.
Any idea why?
Illogical, most definitely not !
Ricd
  • Boat Model: 34
« Reply #3 on: October 21 2018, 21:24 »
Drain hole plugging is an issue on those boats with a single hole on the bow so I guess Salty is right.
Boatname
« Reply #4 on: October 22 2018, 08:32 »
Good one Salty. Wonder why it seems to be just Bav as I’ve not seen it on other yachts.
German innovation  :tbu
Clivert
« Reply #5 on: October 22 2018, 11:06 »
We have a 2001 34 and have never had a problem.
Make sure there's no weed on the chain to block the drain hole
Sitesurfer
« Reply #6 on: October 22 2018, 18:44 »
That explains it then!
I replaced the drain covers with nice stainless ones in the yard before launch and was cursing the incompetence of the shipwright who drilled the holes for not getting them in (normally) perfect Germanic symmetrical order.
« Reply #7 on: October 22 2018, 19:12 »
That all makes perfect sense (and so logical!) but, how odd - I'm absolutely sure my B34/2001 has equal height holes with equal stains on both sides. I've scoured all my pics but there are none bows-on so I'll have to check tomorrow. What's the difference between the holes on your boats? I should add that I always keep the anchor locker clear of mud and weed...
Bav32
  • Boat Model: Bavaria 32 Cruiser
« Reply #8 on: October 22 2018, 19:28 »
The difference is about 3-5cm if I remember correctly
Boatname
« Reply #9 on: October 23 2018, 15:43 »
Mine
Ricd
  • Boat Model: 34
« Reply #10 on: October 23 2018, 16:15 »
Like Bav32 only my port side is the lower one with the rust stain. No stain on higher one. B34-2000
Sitesurfer
« Reply #11 on: October 23 2018, 19:12 »
That looks exactly like mine, all makes sense now!
