Laminated floor change on Bavaria 44 2003
Author Topic: Laminated floor change on Bavaria 44 2003  (Read 3838 times)
elias
« on: October 16 2018, 14:06 »
Hi !
Has anyone tried to make a change of the floor laminated panels ?
Re: Laminated floor change on Bavaria 44 2003
« Reply #1 on: October 16 2018, 22:23 »
Not sure what you mean by change the floor, but all the panels are removable and you can make new floor panels (or have them made) in other finishes such as real teak and holly. However the standard finish is arguably the best in terms of stability of finish, low maintenance and long life. So don't really see any need to change.
elias
« Reply #2 on: October 17 2018, 12:37 »
Thanks a lot for your advice ! Yes I mean the floor panels in the interior .  The thing is that it has collected kind of many hits from objects that fell and has also some decoloration from detergent in some spots . I was thinking the same again material but where can I find a supplier
« Reply #3 on: October 17 2018, 15:42 »
In the UK you can buy it from www.robbins.co.uk Not sure it is an exact match but it has the same type of laminate top layer on 12mm ply backing. They also do real teak
You may well also find a source in Germany, but I don't know the actual supplier. You could try SVB who sell many Bavaria spares.
elias
« Reply #4 on: October 17 2018, 18:29 »
That’s great ! Thanks a lot for your advice !
Noelio Abrunhosa
« Reply #5 on: October 17 2018, 19:32 »
 hi
hawkehouse do a laminate
https://www.hawkehouse.co.uk/cabin-sole-laminate/
regards
Abby
« Reply #6 on: October 18 2018, 00:21 »
They do not actually stock it - the supplier is Robbins and they get it to order from Bristol.
