Bavaria Sport 34 - panel 305 & cockpit panel dead
Author Topic: Bavaria Sport 34 - panel 305 & cockpit panel dead  (Read 10043 times)
Guy
  • Boat Model: Bavaria Sport 34
« on: September 15 2018, 21:18 »
After a severe electrical storm in Spain last night the panels 305 & cockpit control don't function. Having checked all the fuses, (all ok), & relays on the main power board which seem ok I'm a bit stuck! Also has anyone an idea how to open the engine hydraulic hatch, (without using a jigsaw that is!), now that the cockpit panel is down as maybe there's something tripped down there?
12v circuit seems ok as both engines start 1st time no problem, panel 306 - shoreline 220v is all ok and working.
roadtrip
  • Boat Model: bavaria 33 sport
Re: Bavaria Sport 34 - panel 305 & cockpit panel dead
« Reply #1 on: November 08 2022, 12:48 »
You probably solved it by now
Having all the fancy of soft touch buttons on Bavaria is fine until something like this happens
Before resorting to extreme measures I would short the relay for hatch open/close on fuse panel, this will bypass all the brain-deadness of the control board
