2006 Bav interior - ?lighter than Sapele
Author Topic: 2006 Bav interior - ?lighter than Sapele  (Read 4509 times)
Bertie1972
  • Boat Model: Bavaria 30
« on: September 05 2018, 21:02 »
I want to make a rack to match the interior of my 2006 Bav 30 Cruiser.
I've found an earlier forum post in which confirms that in 2002 the interior was Sapele.
However, I've looked at photos of the interiors of 2002 boats for sale and they appear to be made of a darker wood than mine.
Is mine simply lighter Sapele, or was something different used a few years later?
Holger
Re: 2006 Bav interior - ?lighter than Sapele
« Reply #1 on: September 05 2018, 21:10 »
I have read or heard somewhere that it should be Bosse.
« Reply #2 on: September 05 2018, 22:52 »
The woods used vary hugely in colour and grain. Sapele was used extensively but in its natural state will vary, so the factory will choose the colour to get an even appearance from the timber that is available at the time. It is true that the pre 2003 boats used darker woods but were still from the Sapele family.
You will find if you go shopping for wood you will find wide variations so you have to look through and find a match. You can use wood dyes such as Colron to vary the colour, although obviously more to darken rather than lighten.
In my 2001 37 I used a lot of basic mahogany to make book shelves and racks for mugs, spices etc and managed to blend it in well by using a satin varnish finish. I also managed to get a piece of sapele veneered ply to match when adding a shoe locker in the forecabin.
In my current 2015 33 I bought matching mouldings from the factory via Clipper to make book shelves, but I have also used both teak, iroko and mahogany which also blends in well with the lighter trim used on current models.
I am fortunate in having a specialist marine timber supplier locally www.kjhowells.com who has a good stock of a variety of timbers, often offcuts and I root around for bits I know I can get to blend in by using a mixture of dyes and finishes.
« Reply #3 on: September 06 2018, 04:36 »
When I needed a piece of wood to reduce a space after changing the oven onboard, I used a piece of pale white soft wood and coloured it using a Colron wood dye as Symphony has suggested. A couple of coats of the dye and I’m hard pushed to see any difference between it and the original woodwork on the boat. Whilst it was not important structurally, being only somewhere for the shoot bolt used to prevent the oven from swinging on its gimbal mounting while at sea, it was important to me that it matched the colour of the surrounding woodwork. It did !!
Come the winter and one of my next projects is to gently sand off the bulkheads that form the sides for the companionway entrance where these have been bleached by the sun. I’ll then treat them with a suitable Colron dye until they exactly match the interior woodwork colour. It’s not rocket science but it helps to practice on an off cut of the wood you intend to use.
Bertie1972
« Reply #4 on: September 07 2018, 08:15 »
Many thanks for replies guys.
Holger, I Googled for images of Bosse and that's exactly it - brilliant, well remembered!
Thanks again
Baltic
  • Boat Model: B39
« Reply #5 on: September 18 2018, 16:49 »
2006-2007
It was Khaya mahogan...
http://www.stonesmarinetimber.com/products_khaya_african_mahogany.html
SVB list plywood...
https://www.svb24.com/en/boat-playwood-khaya-mahagoni-quality-a-c-2480-x-1200-mm.html
I have used it successfully when making woodworks.
Look like original.
