Auto Pilot ST6000 not holding course
Author Topic: Auto Pilot ST6000 not holding course  (Read 5187 times)
1simon
  • Boat Model: Ocean
« on: August 30 2018, 17:00 »
HI All,
Lately my ST6000 Autohelm Autopilot is not holding course all the time. Sometimes when I swtich to autopilot the helm turns to starboard or port. Soemtimes I switch to Auto and it holds its course.
Is there anything I can check or do before I call a technician?
Rgrds
Simon
Re: Auto Pilot ST6000 not holding course
« Reply #1 on: August 30 2018, 17:21 »
You could use a multimeter to check the fluxgate compass - http://www.raymarine.co.uk/knowledgebase/index.cfm?view=3798
Clivert
« Reply #2 on: August 30 2018, 18:02 »
Has anyone put something metal or magnetic near the fluxgate compass ?
Alternatively is water getting into the motor ?
« Reply #3 on: August 30 2018, 19:15 »
Do you have a rudder feedback sensor - If so I would also check the connection to it.
1simon
  • Boat Model: Ocean
« Reply #4 on: August 30 2018, 21:59 »
Thanks for the suggestions. Will tackle tomorrow.
« Reply #5 on: August 30 2018, 23:22 »
Maybe also check for a loose connection at your course computer terminals.
« Reply #6 on: August 31 2018, 10:59 »
If you have an ST60 'Multi' or a volt meter, check the voltage you're getting through the circuit whilst it's doing the steering. I had a similar problem (albeit with an ST4000+) and discovered an occasional drop in voltage from nominal 12.6v-12.8v down to <10v. This only lasts a fraction of a second but is enough to screw the pilot up. Was caused by (as Salty suggests) poor wiring so replaced with proper tinned cable and no problem since... good luck.
