If you ever damage your rudder water seal ...
Author Topic: If you ever damage your rudder water seal ...  (Read 2844 times)
Boatname
« on: June 21 2018, 20:49 »
Whilst I was having my saildrive gaiter needlessly changed in France (15 years old and still perfect) I decided to drop the rudder and fit a new Jefa lower bearing.
Unfortunately the Parklev dropped the stern of my boat through a radius instead of vertically and it tore the seal that sits at the top of a rudder tube mounted to a grp tube in the transom.
My UK yard gave me the name of a UK supplier and £8.50 later it’s as good as new.
Hope someone finds this useful in the future.
9cm outside measurement, 6cm inside.
tckearney
  • Boat Model: B42
Re: If you ever damage your rudder water seal ...
« Reply #1 on: June 24 2018, 08:56 »
I replaced mine on a B42 with like for like a couple or £ on the internet.  Then realised I could have put a double seal in for just a few £ more.  double seals do not have the metal work and springs open to the elements.  Type "water shaft seals"  into Google.
