what is this part and what do I do to stop the oil leak?
Author Topic: what is this part and what do I do to stop the oil leak?  (Read 3063 times)
Guys,
I have a small oil leak coming from the round part shown in photo on my D1-30. The "Button" is loose but there does not appear to be any way to tighten it. the central part moves around. I could not identify it on the parts diagram on euromarineparts.
It is located near where the raw water pump enters the main engine housing.
Re: what is this part and what do I do to stop the oil leak?
« Reply #1 on: June 09 2018, 17:57 »
Not familiar with that engine, but the part looks like a freeze plug. It's labeled "Expansion plug" here: https://www.marinepartseurope.com/en/volvo-penta-explodedview-7746500-23-35201.aspx
Looks like the thing is fitted with a bolt and gasket coming from the inside of the assembly, so that'll be quite annoying to tighten - the assembly will have to come off the engine. Definitely get the gasket(s) before starting the job, as it'll likely need replacing.
« Reply #2 on: June 10 2018, 02:17 »
Thanks Yngmar,
Looks like a big job for a small leak. I can't see what would have made it fail, given I live in Australia and temperature does not get to freezing.
