control panel schematics/wiring
Author Topic: control panel schematics/wiring  (Read 2752 times)
Jackho
  • Boat Model: B37
« on: May 23 2018, 10:42 »
Further to my original post re: Glow plugs remaining on after start up - having changed the glow plug relay and toggle sw the problem still remains.
The startup cycle is normal but when the engine runs the glowplugs are re-energised hence the need to get a schematic or wiring diagram of the layout.
(or any other advice). The schematics in the workshop manual are not very coordinated so some more info would help.
In the meantime I disconnect the wire onto the glowplug rail after starting engine.
The engine is D1 30 with keyless control panel.
thank you in anticipation. Jackho
Re: control panel schematics/wiring
« Reply #1 on: May 25 2018, 20:09 »
This is what I have - hope they are useful  :)
Jackho
  • Boat Model: B37
« Reply #2 on: June 05 2018, 17:28 »
Thanks for that - my problem is cant match the wire colour to the toggle switches pinout incase I have mixed something up.  I guess there has to be a fuller wiring schematic somewhere.!!??
