control panel schematic
Author Topic: control panel schematic  (Read 3767 times)
Jackho
  • Boat Model: B37
« on: May 23 2018, 10:26 »
Further to my original post re: Glow plugs remaining on after start up - having changed the glow plug relay and toggle sw the problem still remains.
The startup cycle is normal but when the engine runs the glowplugs are re-energised hence the need to get a schematic or wiring diagram of the layout.
(or any other advice). The schematics in the workshop manual are not very coordinated so some more info would help.
In the meantime I disconnect the wire onto the glowplug rail after starting engine.
The engine is D1 30 with keyless control panel.
thank you in anticipation. Jackho
Re: control panel schematic
« Reply #1 on: July 20 2018, 16:55 »
have you solved the problem? I have the same problem. Been advise to change the relays and the key switch on the panel. Could this be a waste of money?
« Reply #2 on: July 20 2018, 18:38 »
Why not just bin bypass the lot and install a push-button for the glow plugs.
